Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 163
Thread: 4G swap in a 3000gt?
  1. #51
    I don't bite
    Southern IN
    Of course it's AWD! The DSM ATX trans is the same as 6g. I'm even using my 6g tcase.
  2. #52
    I know that. What I don't know offhand is if the transverse 4g63 puts the transmission/t-case any more offset than the transverse 6g72. I wouldn't think so--based off the 2g DSM's, but it can always be a little squirrely transplanting a foreign engine in & having to deal with new mount locations, etc.
    So the DSM driveshaft bolts up to the 2g VR4 rear ok? I wasn't sure if length was a problem....
  3. #53
    Nice work! I expected a hype thread too. I've had several dsms as daily drivers and really love that motor. Simple to work on, parts are cheap, extremepsi is awesome. I deleted the balance shafts on all of mine and had no regrets. My friend (korndoggocr on the dsm forums) had a 2.3 stroker dsm with a big ball bearing turbo. He stripped the teeth off of 4th gear in a built shep trans, and 2 built jacks trans. Jack made him a special build where he used an evo 3rd/4th gear. I guess they were wider. That transmission worked great for him.
    Built motor, DR750s, AEM and Meth
    http://www.802projects.com
  4. #54
    I love all of the naysayers. I find it hilarious, actually.
    Definitely a step in the right direction when you bring up the word "fun". Can't wait to see this thing tearing up the streets/track.
  5. #55
    August 2010
    Chicago
    Quote Originally Posted by AudibleSilence View Post
    My questions were rhetorical. I already made up my mind that this was dumb. No point in trying to see the point in putting a 4G in a 3/s. It's backwards.
    This will end well.
  6. #56
    As a builder and fabricator, My hat goes off to you. Vary nice package indeed. I have nothing but respect for those that bland performance parts to create something that was not.
    I can see this car pulling vary well through turns and accelerating hard out of the turns. Many think drags is all there is to life. I happen to prefer road course style performance and believe
    this car will have many advantages over many hard boosted 3.0 VR4s. I vary much so like what you have done here. Anyone that can complete an Idea or dream deserves a full round of applause.
    So here I sit clapping at a project well done. Congrats.
    Mods
    2ND place Autocross NG09
  7. The Following User Says Thank You to GTwizard For This Useful Post:
  8. #57
    finally something interesting on the forums
  9. #58
    Madison Heights, Mi
    closing thread for a moment
  10. #59
    Madison Heights, Mi
    If you feel like bitching about this build or commenting on how stupid/retarded/what ever it is use the following link.
    Failure to comply with this is not an option.
    http://www.3sgto.org/3000gt-stealth-...4g-3000gt.html
  11. The Following 5 Users Say Thank You to Alan92RTTT For This Useful Post:
  12. #60
    I lack color... verified
    Aug 1998
    Does Buschur still make a forward facing turbo manifold setup for this engine? It was quite popular for guys to run a smaller radiator and have the turbo draw air from the front of the car. The advantages of it were for more space with a large turbo.
