Got everything buttoned up today. I cranked it for a while with the Cam and Crank sensors unplugged to build oil pressure. Once I saw the needle move a little I knew I had some oil flowing.
It smokes a little just sitting there idling, and even more while driving. I figured it would because I found some coked up oil in the exhaust ports of a couple cylinders. I thought about putting valve stem seals in it but decided against it. My plan is to pick up a set of second gen TT heads and rework them.
It has a bit of a misfire, it's pretty bad actually. I thought maybe I left something unplugged, but nothing found from what I can see. I think it might be the coils, I used the ones that came on the engine since they looked cleaner, maybe it has a bad one.
Now I need to get the interior put back together and load cleaned up so I can get it loaded on the trailer for the trip to PA tomorrow!
