Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: Newest LCDBC device $230 shipped
  1. #41
    Payment received, I'll test it out today to make sure it's perfect, and then mail it out tomorrow.
  2. #42
    Hiya BlackStealth, forgive me for asking, but how do I tell which version of the hardware I have? I want to be sure I have the latest software.
    * Evo8 MAF * TD04-16T * Delphi 780cc * FIPK * Full Custom Exhaust * Hotwired Supra FP * Megan CO *
    * GReddy FMIC * Nitto 555's * Avic Z3 * BlackStealths LCD/BC *** All else stock *
  3. #43
    Quote Originally Posted by Simace View Post
    Take a pic of it with the cover off and I can tell you. Also, it helps if you can tell me the software version it is using right now (version number is displayed briefly when you enter into config menu).
  4. #44
    Will do...thanks m8!
  5. #45
    Aug 2014
    2014/2nd one, 1996 1st
    Well, after a lot of trepidation, it's here in London.... arrived a couple of days ago but I've not had time to play with it yet. Looks great, well made, mate!!!
    Will try to dummy it up this weekend and fit it in the spare Speedo cluster. Gonna take some accurate measuring and cutting to make it look just like it came out of the factory that way. Awesome!!!
    Ted
  6. #46
    Aug 2014
    My car uses the PLX Wideband and it works fantastic. Innovative LC1, LC2 also works good too. AEM I'm not so sure, I heard one person had to make some adjustments before the numbers were correct -- I don't know if he had the signal split into many places or what.
    So those approved use the Bosch WBO2 sensor and a controller to trigger/create the output to your 2 wire input.... I'm looking at 2 options:
    INNOVATE LC-2 LC-1 AFR WIDEBAND CONTROLLER + O2 BOSCH O2 SENSOR 3877 | eBay or
    ZADA TECH WIDEBAND AFR CONTROLLER AND BOSCH LSU 4.2 SENSOR | eBay which is more compact and single-purpose.
    The LC-2, whose description implies you have to calibrate it with their PC software before use... bearing in mind my purpose is just to monitor, log and maybe use a Neo AFC to tweak so she runs better, mild tuning maybe later, can anyone advise me if the LC-2 is a straight plug-n-play or does it need setting up to work with the LCDBC?
  7. #47
    The LCDBC only has 1 wire input for WBO2, the second wire on the connector is for Auxiliary input.
    Personally I would go for the LC-2, it's cheaper and has more features that you may use in the future. I would think the LC-2 would be plug and play without a PC if you're satisfied with their default settings.
  8. #48
    Aug 2013
    Are their any left Antero? These look great! i'm interested in purchasing one. i'm from Sydney Australia, what would the total cost be including shipping? i would need the correct cable to suit a JDM 96' GTO MR.
  9. #49
    Yes I will have 10 LCDBC available in about 2 days. I have to print new ABS cases for them, as the design was slightly changed.
