GNC has been canceled
Grill N Chill @ 4:00
1. Paul (green-lantern)
2. Ginger (futurevr4man)
3.
4.
5.
6.
7.
Devils Triangle @ 12:00
2.
3.
4.
5.
I havent decided on devils triangle. Ill lean toward no, but I may change my mind. If I fix my strange fuel pump issue, ill definitely do it.
What's the fuel pump doing?
When I go around a corner (I think when I take a right) quickly it will spit and sputter like its out of gas then be fine once I'm straightened out. Even with a full tank.
That is strange, pull the pump and check it out. Maybe a bad connection?
Paul, if your car is running I'll probably ride with you. Either case, I'll likely get there a bit early to help you try to get everything set up.
OBX diff was the problem.
quit buying cheap diffs!
Ill pull my fuel hat and see whats up. If i can fix that and also get my thermostat taken out, then ill be all over the triangle, and good luck keeping up pony boy!
How is it missing 2 spring washers? Wouldn't you have noticed that on reassembly? Or are you saying that they came out and are somewhere in your transmission?
