Results 11 to 20 of 24
Thread: Srs
    Nope. It wouldn't make any sense to me that any car would honestly. If there is a seatbelt error the airbag is a back up. If a seat belt error causes an airbag error, then doesn't that defeat the purpose?
    Stealth owner since '91
    Sthrn NH/Eastern Ma
    So I guess the 3000GT/Stealth doesn't have these sensors?
    Nope.
    Also, disconnecting the battery only seems to work if the light was triggered by a low battery condition.
    All other errors are stored, and maintained by the SRS unit's internal battery.
    They can be cleared by the $ealer..
    FWIW the low battery condition can also be cleared by turning the key off and on (don't start the car, just turn it until the dash lights up) 30 times. (I guess that's supposed to be ~ two weeks of driving assuming two trips a day?)
    BTW - I agree with Stealthee, tying the seatbelts into the SRS doesn't make any sense..
    You might be thinking of the Butt sensor that some systems use to enable the passenger side air bag?
    Twin Turbo verified
    Melbourne, Australia
    It's part of the safety restraint system and will give a warning to say it's not working. I have seen this on Volvos, Fords and GM. However our cars must not use it.
    [QUOTE=Steve '92ES;22618]Nope.
    I think I will give that a try just for the hell of it.
    Medford OR
    I won't touch the making sense part... That's the engineer's department. I just fix them and don't try to make sense of it all. But in comparison, our restraint system is pretty old school. Most modern systems have seat belt pretensioners that blow the seatbelt buckles back in a crash, as well as body weight sensors in the seats. I fix seatbelt related SRS codes all the time...
    Gilbert, AZ
    So what is the potential issues with the SRS light? Airbag wont work?
    I have had this light on for about a year now but never cared since I heard a lot of people get this random light for weird reasons. My seatbelt doesn't feed itself back in but I dont know if that is the reason or not.
    Medford OR
    Quote Originally Posted by mikeyVR4 View Post
    As has been stated, a 3S SRS system does not monitor or know anything about the status of the seat belts... The consequences of the light being on vary depending on the code. The system could be fully operational with a code in memory, partially handicapped, or fully shut down... I've never really checked into the failure management strategy on these particular systems, so I don't really know the specifics of how they handle each different code.
  8. #18
    Twin Turbo verified
    Unless you put a scanner on it you won't know what is causing it. Your airbag might or might not work.
  9. #19
    Time for a trip to mitsu
  10. #20
    Medford OR
    Any shop with a Snap-On scan tool and the Asian software can hook up to the SRS. That's all I use...
