Something else got accomplished over the weekend and that was all the PnP mods for chrome. Wired in the Active Exhaust switch with bulb and completed the missing wire from the dash harness to the ECU. Ill do a better write up later but here's the general idea (91-95 cars do NOT need to do this if you have a Jesters ECU)
Start off by removing the driver side kick panel and here you will find 2 white connectors. The lower 18 pin one is the one we need.
I have to confirm the 96/97 cars are like this but for sure the 98/99s are missing one wire. There's 4 wires on the dash harness side (male connector) but only 4 on the engine harness side (female connector).
Note, in that above pic I have removed the harness plug pin stay clips which look like this:
The green one is from the ECU connector. The pink is from the dash harness. They come off easily with just a small flat head screw driver.
The ECU plug for the true 98/99 ECUs is pin 73 (I think, gotta double check). This is the plug. It's the "top one" with the ECU installed. Note in the upper left corner is the red wire with 2 blank spaces below it. The second from the top is the pin for the AE input.
Thanks to Jeff and my spare SL harness I had the pins I needed to make a wire that just plugged into the connectors.
Note: the female pin for the dash harness connector is the same pin as the amp harness plug!
Here is a bad picture of the wire installed and the stay clip reinstalled. I'm holding the plug upside down... It's the yellow wire that's the AE pin installed. Which you can't even see... Haha ill get a better pic later.
Here's the whole setup.
Ill to back and get better pics later for the "official" write up. I was in a hurry when I did these.
Those of you who are twitching for switchable maps might want to make sure this setup works in your car. You can log the AE switch in chrome with EVOScan. The bit should change to 1 when the Tour light on the dash is on.
