I need to get on the classic plate bandwagon. Been meaning to for a while, as I know mine will not pass emissions lol... hasn't in 10 years haha.
No sniffer test in my county. Just a "visual."
On another note: went over to the garage during lunch to test the lights and discovered the passenger HID is out and the hazard lights don't work. Oddly, the turns do. The hazard switch is plugged in and mechanically functions so I wonder what the issue is there.
Well the hazard lights were an easy fix. Someone installed a 7.5amp fuse in the 10amp slot for the hazard fuse in the engine bay box. Swapped in a good 10amp fuse and they work again.
HIDs turned out to just be a bum bulb. While I can't visually see anything wrong with it, swapping just the bulb from the drivers side worked. They were 9006 6k bulbs origonally and have a slight blue hue to them. Ordered a pair of 5000k bulbs for a more white OEM look.
The kit is from DDM and has the thinnest ballast I've ever seen. Everything about this kit is nice PnP fun setup. It's only the 35w setup too so I imagine the 55w would be blinding.
DDM Tuning 35W and 55W HID Kits
Just waiting for my tags to get here so I can drive the car on the freeway to test alignment and see how well these poor tires have held up after their vacation.
I'm running the same DDM kit and am very satisfied, however my order took quite some time to arrive. Hopefully you get your new bulbs quickly!
I'm also running that same kit. Thinking about getting them for the fogs as well.
By the way those thin ballasts can be attached to the floor of the headlight buckets with double stick tape and they don't interfere with anything. The wires pretty much tuck down there too.
One side is wired backwards and had to plug in backwards to work..did u check the bulb in the drivers side? Or vice a versa? I didn't have a de pinning tool so I never fixed it correctly...
Jason
