Sorry to resurrect an old thread, but this is all new learning for me when most of cars on here are perhaps no longer around or long since set-up fine
I have a 93 engine that I rebuilt, re-bore and plus-sized pistons, mounted in the rear of a small car running 4 wheel drive. I get a lot of noise as the motor is near solid mounted with the rear diff (engine transverse backwards with Ford 4x4 gearbox) mounted to the engine and a driveshaft jack-shaft also mounted to the other side of the block.
Reading through this thread has helped my understanding, but i'm uncertain to whether the ECU is thinking it is seeing a faulty sensor because it is or because of the high background noise.
Battery does get disconnected frequently so I get the learning function, but it does it persistently around the same revs. I tried backing off timing but got the same. I have plugged in another sensor (though didn't bolt it in) and had similar result but didn't get a log for that.
In the data I see a drop in knock voltage and knock base right after the RPM background switch over point at 4406 rpm, just before the 9 count incident which flat lines the timing, but only lasts for 4 seconds and returns to .2v whereas the knock count doesn't recover. To me, the above makes me think is is the noise but don't wan't to start adjusting without some moral support and first event of the year is in 3 weeks!
Are you able to walk me through how to tell if it is real or false knock please Greg?
Next step I was thinking of doing was replacing the sensor then running isolated wiring direct to the ECU.
