Results 11 to 20 of 43
Thread: THE Flash ECU knock sensor thread
    Quote Originally Posted by kywhitelightning View Post
    I did just the opposite last year to find the lowest race gas grade I could use and found out VP110 didn't measure up one bit to C16 lol. I started with C16 and felt nearly invincable. Ran that out and mixed another batch with VP110. This had nearly the same result as running just the 93+meth I normally ran. Maybe I was spoiled with the C16 results but there was a HUGE difference between the two. I won't run anything other than C16 on top of 93 when making glory pulls.
    Like Greg said, I wouldn't do that if I were you. Besides, you are still running E85 all the time, right? That stuff seems to have quite a high ceiling for power capability.
    Jeff
    nah, im not going to. The only thoughts I had was to use a fuel that would show up on the knock sensor to help find what the engine likes in general. Then when going back to the better fuel you'd be plenty safe. Since e85 doesn't really show knock on our setups you just have busted parts before you know it.
    Sent from my RM-845_nam_vzw_100 using Tapatalk
    I lack color... verified
    Aug 1998
    Am I just seeing things or does knock have to be learned by the ECU.
    Correct. It's a lot like a fuel trim.
  3. The Following User Says Thank You to Greg E For This Useful Post:
  4. #13
    Low & Slow verified
    Fortson, GA
    At least now I have an explanation for what I seen instead of adding timing quelled knock, lol.
    Keep up the great work. I'll be ready to start tinkering again soon.
    Jeff
  5. #14
    yeah on my old car the first pull of the day would sometimes have some knock and the rest wouldn't. The evo guys at least say not to make adjustments to your tune unless you can get it to knock in the same place each time. A little risky, but they have a little more forgiving bearing setup.
  6. #15
    Aug 1998
    There's a number of tuning techniques ill get into later when I get some more logs to show.
  7. #16
    www.chromedecu.org verified
    DFW
    Nice.
    That was some horrible knock on that example log.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  8. #17
    Keeping it real...
    Oct. 2006
    Reno, NV
    Man! I was wondering why the white stealth would knock so bad and was pulling timing. Bet it is that damn 3sx pulley.
  9. #18
    Aug 1998
    Quote Originally Posted by Jesters Deadd View Post
    Nice.
    Yeah it's a good thing this car doesn't make any power otherwise the owner would be in trouble.
  10. #19
    Aug 1998
    Quote Originally Posted by ChargerX3 View Post
    Maybe but doubtful. The consistent increase in noise should eventually get filtered out.
  11. #20
    Keeping it real...
    Oct. 2006
    Reno, NV
    Just one more reason to dig into her.
