Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 97
Thread: Rebirth of a street beast
  1. #51
    Low & Slow verified
    Fortson, GA
    Good progress!
    So what are you planning on changing from last build/tune to keep it alive?
    New parts!!!! After many conversations with Ray, what happened to mine is the result of YEARS of abuse to include a bent connecting rod on #3 a few years back. Plus the fact that it was always on kill (There was knock, I'm not gonna lie. The pistons this go around looked flawless on the face.). The crank had 138000 miles on it. He said they crack. Then they bend. It is common with high HP. Call it the entry fee for big power.
    I bought 21psi wg actuator springs to lock me at that boost on pump gas. I plan to only turn the bc on when running race gas. They were installed today!!
    I also pulled the timing map back a little and called it my pump gas map. The race gas map is what I used before and it will stay untouched.
    At the end of the day, on a regular basis I will excersise more caution and, on occation, I will throw caution to the wind and chase that big number (700).
    Edit: I have also put the meth injection system on steroids. Testing netted over a 15% improvement in flow. I still have to test it with it fully installed but, I'm pretty sure the numbers will still be there. More octane and more cooling all the time.
    Installing remote doorbell to avoid the annoying knockers...
    LOL!!!!
    Quote Originally Posted by vr4tune View Post
    sounds dirty!
    It was, until I cleaned it up and lubed it all over. Now it's wet and happy!!!
    On that note, all holes are full!!! Tomorrow, rear main, oil pump, oil pan, knock sensor, and heads. This may or may not all get done, but it is possible.
    Jeff
  2. #52
    I don't bite
    Southern IN
    Billet crank sounds like the real fix then.
  3. #53
    August 2010
    Chicago
    yep...couldn't have said it any better. Its the 'permanant' solution to the crankflex problem. Which is the real reason why I'm trying to shoot for low tq numbers..
    oh and Jeff...you're a kinky mofo...get a room!!
  4. #54
    It is kinda sad, you add forged pistons and rods and the crank fails at the same point the stock rods have been pushed to anyway. I guess mitsu built a pretty well designed engine, all the parts fail at the same time if the tune is clean and the engine is fresh. I'm hoping I have a little more strength in the 74 crank, but then again maybe my wrist pins will get beat up.
  5. #55
    Oct 2011
    Sundsvall, Sweden
    Sorry if I this is a rookie question but what seems to be the safe limit hp/torque wise for a fresh stock engine?
  6. The Following User Says Thank You to Unlogic For This Useful Post:
  7. #56
    August 2010
    Chicago
    Pampena says @500hp his motor took years of abuse. Above 500 the wear rate increases..how much more depends on tune, operating conditions, etc..
  8. The Following User Says Thank You to NOMIEZVR4 For This Useful Post:
  9. #57
    The Panda Not Verified
    Washougal WA/Portland OR
    I've been at 500whp for over 30,000 miles. No problems!
  10. #58
    alamogordo, nm
    good to here you got the beast going back together!
    and PS., as of today there is a new DR750 record holder (i'm sure there will be a thread soon) so the fight for the most powerful DR750 car is in full swing. (I'll give you hint, it's not quite 700 awhp but very close but the TQ is well over 700 awtq). So Fist to brake 700 awhp is still up for grabs.
    93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
    2001 Dodge Viper GTS Heads/cam/Paxton 873 rwhp & 803 rwtq
    95 RT TT 604 awhp 611 awtq (DR750's, and stock motor)
    2004 F350 Harley 14.4@90mph at 3600ft
    04 Lambo Gallardo (sold)
    95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
    92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
    95 RT TT 10.88@129.1mph @3600ft (sold)
    There are 2 ways to make a car fast.
    #1 use the Right combo of parts
    #2 Throw so much money at it that the car has no choice but to be fast.
    I choose #1
    Click for US 3S Fastest ET list
    Better to be a racer for a moment then a spectator for a lifetime
    "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
  11. The Following User Says Thank You to SnakeSkinner For This Useful Post:
  12. #59
    August 2010
    Chicago
    really!....damn...who is it???
    Thats a hell of a feat especially for TD04's....
    34XXlbs..
  13. #60
    I don't bite
    Southern IN
    Still can't believe how much hp you can cram through those tiny little bastards! Great product Matt.
