Does anyone know where I can buy solid front subframe bushings front? Tks
Never seen em marketed or offered. I went with poly. The Energy suspension bushing kit for DSM front sub frames works for our sub frames and only costs like $46.
Are u saying the solid bushings ruined your transmission? Lol
No, the worn out stock rubber bushings caused wheel hop, because I shouldn't have had any with the solid motor mounts.
