SALE PENDING! 98'shortblock(4bolt forged crank) had around 30k and spun bearing compression checked 5miles before it happened(165 x board!) crank is turnable,motor is orig never rebuilt! Jim(814)493-7199
option 1) 4 bolt block(professionally clean by engine shop)all rods,pistons/rings(all good), forged crank(needing turned)$495(plus ship)
option 2) 4 bolt block(professionally clean by engine shop)all rods,pistons/rings(all good), reman forged crank all new bearings you assemble $795(plus ship) $100 LESS W/READY cast crank(4 bolt w/cast crank still a step above 1st gen setup!)full rebuild kit,inc;all new pistons/rings,thrust,full gasket set(new in pkg) add $265($1060)
option 3) 4 bolt block(professionally clean by engine shop)all rods,pistons/rings,(all good) reman forged crank/new bearings assembled $1275(plus ship)$100 less w/cast crank!
Pics of engine and car below!(so you know it wasn't outta some junker or a beater!)over $20,000 in this car! NEW LOWER PRICE $100 LESS REGARDLESS OF WHAT COMBINATION YOU CHOOSE!
2nd gen(98'?) 30k orig miles on engine,compression was about 157(all within 1-2 psi of ea. other!) this is for shortblock(needs assembled)comes forged crank,crank needs turned (due to lightly spun bearing),stock pistons/rings, pics are of actual engine and the car it was in just a cpl wks ago!! I have over $20,000 in this car(pics only to show it didn't come out of a beater!)engine comes unassembled as most wanna know what they have when its being put together and know it will be done right! shipping to lower 48, Alaska/Canada more Note: I have just lowered my price by a few hundred!!!!
Engine has been cleaned by a speed shop(acid tanked,pressure washed ect!)to look like almost new condition! cost me $80
(814)493-7199 Jim
also wanted to mentionnly 6miles were put on engine since pics were taken!! just added pic of pistons, UPDATE: ok just got block back from speed shop(lets just say it came back way better than i ever expected!) block looks new! they removed and replaced all the freeze plugs before/after tanking it! i painted block w 2000 degree alum color high heat paint(taped everything off!)not a rush job! all deck surfaces look absolutely sweet!,i sprayed all cyls,decks,inside all thread holes,water jackets w/white lithium grease!(everything but painted surfaces!) keep in mind the motor only had 30k original miles(so cyls do not need bored,pistons should just need new rings ect!)this motor i hate to say looks way better than the high performance short block i just bought that has 1,500miles on it!(for real i only wished my new one was this nice,not bitchin James as u really looked out for me lol!, but this one is mint!!) if you are wondering a cpl of the pics shown have a coating of white lithium grease in the cyls ect!(to protect surfaces from moisture/rust ect!)these pics do no justice lol!(the inside of this motor looks just like on that came off a factory shelf!) other than the marks from old head gaskets ect! cpl serious sales pending,but no cash in hand yet! may consider partial trades as well? thanks Jim(814)493-7199 SALE
