I bought the car completely stock in 2000 and modified it over the next few years. Then I tore it down and rebuilt it to what you see now. I built the entire car myself except the paint work and custom roll cage. I did all the fiberglass interior myself as well as the motor swap. It took me 3 years to complete and I've had it on the road for 4 years this way. I'm getting ready to tear it down again and rebuild it for v3.0 so stay tuned.
Current Modifications
Engine / Drivetrain:
Twin Turbo motor swap and full car wiring swap
... Motor and tranny painted House of Kolor black pearl and tangelo pearl
Rebuilt stock td04 9b turbo’s
Shaved front valve cover
Cruise control delete
Hallman Pro manual boost controller
Apexi AFC Neo w/ Boomslang Fabrications plug & play harness
Walbro 255 high flow fuel pump
Pampena Motorsports fuel pump hotwire kit
Innovate Motorsports LC-1 wideband air/fuel controller
Extreme Turbo Systems stainless steel front mount intercooler kit
DN Performance headers and pre-cat eliminators
DN Performance twin turbo pre-intake pipes
Tanabe concept g-blue turbo back exhaust system
Random Technology 3" catalytic converter
Turbo XS type S RFL blow-off valve and adapter
Spec stage 2 clutch
Spec lightweight aluminum flywheel
Fidanza adjustable cam gears (blue)
Quaife AWD front limited slip differential
3sx polyurethane motor mounts
3sx fuel rail loop adapter kit
3sx polished water distribution housing
3sx polished egr valve
3sx polished upper intake plenum
3sx polished lower intake plenum
3sx polished fuel rails
3sx polished radiator cover
3sx polished spark plug cover (twin turbo)
3sx lightweight aluminum crank pulley
3sx chrome oil cap
3sx chrome cap covers bundle for n/a
3sx mirrored stainless steel intake support bracket
Rebuilt and polished throttle body
Totally Stainless socket head bolts for entire engine bay
Ultimate Performance mirrored stainless dress up kit
3sx oil cooler kit
3sx braided stainless turbo oil lines
3sx braided stainless clutch slave cylinder line
K&N intake filter with M.A.S. adapter
Taylor orange spark plug wire set
NGK platinum spark plugs
Flex-a-Lite dual 12" puller fans (black)
Samco sport black silicone radiator hose kit
Stainless steel t-bolt clamps for intercooler pipes
Topline engineering 10 ga. ground wire kit
Fuel pressure adapter kit w/ gauge
Billet aluminum battery mount
Stinger spv69 car audio battery
Suspension:
K-sport coilover suspension system
Front twin turbo brake conversion
Powerstop cross drilled rotors
3sx stainless braided brake lines
19”x 8” Falken torque 5 chrome wheels
235/35/R19 Falken st 115 tires
3sx rear lower adjustable control arms
H&R 15mm wheel spacers
Orange painted calipers
Body:
House of Kolor Tangelo Pearl paint w/ Snow White Pearl and Black Pearl graphics
AIT Racing full BMX body kit
GTP V*RFP gt300 fiberglass hood
3sx low tension hood struts
Aerocatch hood pins
APR performance gtc-200 universal carbon fiber wing
91-93 3000gt front marker lights
94-99 3000gt taillights
Shaved rear wiper
Import Precision vertical door kit
H4 diamond headlight conversion
Pivot variable pop-up headlight controller
Interior:
Digital A/C conversion
Midnight Haze triple ‘a’ pillar gauge pod
Speedhut wide band air/fuel gauge
Speedhut boost gauge
Speedhut oil pressure gauge
Speedhut water temperature gauge
Speedhut volt gauge
Speedhut main cluster white gauge overlay kit
Stewart Warner G.U.S. tachometer gauge
Hornet security alarm system
Ultimate Performance short throw shifter
3sx aluminum dash defroster vents
3sx aluminum pedal covers (twin turbo)
3sx aluminum door sill covers (stealth)
Stealthmode93 full fiberglassed interior painted Tangelo Pearl and Black Pearl w/ Snow White pearl pinstripe
Corbeau a4 black micro-suede seats
Corbeau seat rails
Corbeau blue 4 point racing harnesses
MOMO black trek steering wheel
MOMO steering wheel hub
NRG Innovations quick release steering hub
MOMO race shift knob
Piranha Fabrications custom 8 point roll cage painted House of Kolor True Blue Pearl
Split collars for harness bar to secure racing harnesses
Totally Stainless socket head bolts on roll cage
Stealthmode93 custom carbon fiber door bar covers for roll cage
Stealthmode93 custom carbon fiber switch panels in center console
Black leather e-brake handle/boot
Black suede upholstery
Factory carpet dyed black
In Car Entertainment (ICE):
3- 10" Memphis Audio pr subwoofers
1- 6.5" Memphis Audio pr component set
1- 6"x9" Memphis Audio pr coaxial set
1- Memphis Audio pr4x50 amplifier
1- Memphis Audio pr1x1000 amplifier
Eclipse avn-6620 headunit with GPS
Eclipse i-pod adapter
Mobile Spec 6 farad hybrid capacitor
Stealthmode93 fiberglass stereo enclosure
Body Lighting:
Nova strobe lights for headlights and taillights
2- Oznium 9.5” flexible L.E.D. strips (blue)
2- Oznium 28” flexible L.E.D. strips (blue)
3- Oznium 6’ flexible L.E.D. strips (blue)
1- Oznium 38” flexible L.E.D. strips (blue)
Engine Bay Lighting:
4- Oznium high intensity L.E.D. flood lights- (blue)
8- Oznium surface mount L.E.D.’s (blue)
2- Oznium 9.5” flexable L.E.D. strips (blue)
Interior Lighting:
4- Oznium 28" flexable L.E.D. strips (blue)
46- oznium surface mount L.E.D.'s (blue)
5- Oznium L.E.D. Blue rocker switches
All stock lighting converted to blue L.E.D.’s
