First off, awesome vid Dan! Love to see videos of things like this!
In belt design there is always a slack side of the belt, and this is where the tensioner pulley is located. As the slack in the belt changes, the tensioner is there to take up the varying slack. As my earlier quoted post said, timing belts with fiberglass cords do not stretch. The reason the belts appear to get longer as the motor is running at higher rpms is because the force on the belt is higher. As the force goes up, the teeth begin to compress and the belt starts to get more slack, and the tensioner is there to make up for that.
The stock Mitsubishi belt is the basic design as the Gate aftermarket belt, the Gates racing belt, and any other aftermarket belt. Synchronous belts all have three basic elements, a nylon jacket that is on the face of the teeth, tensile cord members, and rubber. It is there to prevent wear, and to reduce noise.
The tensile cords, which can be made of many different materials. We make belts with fiberglass cords, polyester cords, aramid (kevlar) cords, carbon fiber cords, and even belts with steel tensile cords. All cam timing belts have fiberglass cords, because fiberglass does not change in length. Polyester cord shrinks as it sits over time, aramid soaks up water and grows, and steel just wont break first.
The last component is the rubber. There are many different rubbers we use from EPDM to neoprene, to nitrile, and chloroprene rubbers. The HSN rubber used in cam timing belts has a very high temperature range that it works over, and temperature does not effect the length of the belt. Our racing belt uses nitrile rubber that is reinforced with aramid fibers to make the teeth stronger and less prone to sheering off and compressing at high loads.
Now in production when we build the belts, we actually use a large mold that is up to 48 inches wide, and we basically build a belt that is 48" wide and then grind it to the correct thickness, and cut it to the correct width. After the belt is in its finished state, a certain number of belts are taken and measured for the pertinent dimensions. One of those is length. There is a specified length for every belt we make, and we verify that the belt meets this specification before it leave the facility. The calculation to figure out that length (with two equally toothed pulleys) is:
((#teeth of the belt - #teeth of one pulley)/2) * Pitch of the belt
Just to prove that timing belts do not stretch over time, I measured the timing belts out of my dad's 1980 Honda Goldwing at work after he replaced them. The belts on his bike were probably made in 1979. Even after 40,000 miles and 32 years on his bike, they were still within the specifications!
Lastly, I will try to answer why timing belts seem to break unexpectedly. By far the most common reason we see a timing belt break, is due to mis-installation. There is a minimum bend radius for the belt, and if it is bent beyond this, it can crimp the tensile cord and severely weaken it. Fiberglass is great in tension, but not in compression. Believe it or not, but you could lift a stock AWD 3/S off the ground with the timing belt, it takes that much force to break one. When the cord is crimped, it can reduce this force by over 50%! I will look up at work on Monday what the minimum bend radius is for an 8mm pitch timing belt.
I can measure the belts if you want to send them to me Dan.
If anyone else has any other questions feel free to ask, and if I cannot answer them, I will find the answer out from some of the design and application engineers at work.
Oh and PS just a fun fact, the stock Mitsubishi belt from the dealer is a Gates belt, made on the same line as the racing belts (in Japan). There is no difference in the dimensions of the belts between stock and aftermarket whether its a Gates belt or not. The only difference between them is the materials that go into the belts.
Whew long post...
