Originally Posted by
Jimvr4
My way of thinking about the trims is that as long as they aren't pegged at -12.5 or +12.5 they ARE set as well as they can be given the components. So that brings the next question. Do you know the history of the injectors? Were they cleaned and flow tested? How about the O2 sensors - are they unknown age? You may want to consider buying new ones if that is the case. Also the MAF needs to be connected and providing stable air readings, intake temp, and baro. The motor should be pulling a healthy vacuum of ~ -450mmHg.
