First time out with the current setup -- pertinent mods:
PTE 74GTQ .81ar journal bearing -- old school dinosaur-tech..!
PHR turbo kit - (new style) open tubular manifold, single gate
4” dp/mp; Apexi N1 catback (necks down to 3” at the flange and then to 3.15”)
GReddy 3-row
Gforce ECU w/ 7400RPM rev-limit; VPC/AFC NEO
GSC S1 cams
GSC Beehive springs & Ti retainers
SupraStore fuel system -- 880cc injectors, Wally 400
Mix of VP110 and C16 -- cumulative octane was 110-111 MON
100% STOCK Ignition - 4644's gapped at .032 - NO DLI!!
TRD Diff
CCW Drag Pack w/ 26x11.5x16 ET Streets
Previous dyno #'s here: http://www.3sgto.org/other-platforms...ra-dyno-s.html
1st Pass -- Boost peaked at ~20psi; tire pressure 14psi cold. Intended to be a shakedown pass. Bogged the launch BAD and smacked the limiter on every shift..! LOL The car hooked nicely to say the least, and tracked straight as an arrow with my new alignment. 11.69 @ 131.32MPH w/ 2.10 60....
2nd Pass -- Boost peaked at 23.6psi; steady 23psi. Got more aggressive with the launch and spun fairly hard. Clean pass otherwise but smacked my 7400RPM rev-limiter right at the traps. 10.41 @ 138.31MPH w/ 1.61 60'
3rd Pass -- No changes. Spun hard on the launch and spun hard and wheel-hopped through 2nd gear.. 10.63 @ 137.69MPH w/ 1.68 60'
vids below
4th Pass -- Dropped tire pressure to 14psi (warm). Bogged the launch BAD and short-shifted 3-4 which hurt my 1/8 MPH. 10.66 @ 138.35MPH w/ 1.75 60'
vids below
I really wanted to make another pass but it was getting dark and the temp was dropping so we decided to pack it in. Overall I'm pretty damn pleased with how things went first time out! I knew the 7400RPM limiter with a 26" tire was going to be an issue beforehand. I didn't plan to turn it up any farther today since 22-23psi is my VP110 'street tune' which I get locally at the pump.
