Just doing my yearly TC/output shaft service for my 5-speed & was a little bit freaked out how easy it was to crack the drainplug loose, so I have been looking into torque # for it. The FSM states 5.5lb for the drain plug on the 5-speed transaxle & due to the same thread/length I figured that would suffice. But, The Stealth316 fluid change states 22-25 for the TC drain plug & 18-20 for the fill, doesn't distinguish between the 5-gear or the SS 6-gear. The TC recall info in the FSM calls for 300in # (25ft lb) & it also doesn't distinguish any difference between the 5 & 6 TC's. What are you guys getting away with?- don't want to take it too far (25 sounds like a bit much), but I'd rather the plug stay in place.
I have been running the Redline MT-85 in the TC, was going to change to shockproof heavy- but read too much about venting out. Anyone running the Redline 75-90 GL-5?
