It would be very interesting to see if you could get the Aeromotive 340 to work with the stock FPR. I've been considering the same setup myself.
I've got a two step on my Supra pump that doesn't need ANY resistors. I bet it will work on the AEM 340 as well.
Wow![]()
Why not run aftermarket FPR? I can bring the FP down at idle on a hotwired walbro 416 or twin 340's. Then you have the ability to raise FP if you need to also.
Edit: Great info BTW and thanks for posting!! So much guessing and hearsay on this subject. Glad someone provided real data.
Pretty sure my Walbro 255 is over running the stock FPR at idle, I guess I should put a gauge on it...
I see in your sig you have an AEM... That allows you to prime the system for startup. We can't do that with a stock ECU. Find me an aftermarket regulator that won't leak down, and I'd be interested. Cranking on your motor long enough to build fuel pressure gets annoying.
That, and I like the idea of slowing the pump down and not working it so hard when it's not needed.
