Here are a few more pictures for now:
Giiiirdle
Journals exposed
#6 thrashed and wedged between lobes
Cylinder #6's piston, rod, cap, and bearings; you are the weakest link hahaha.
It is official; I managed to punch a hole through this block.
Giiiirdle
Journals exposed
Jeff - I will have more up soon. Hopefully these suffice for now lol.
Adam - Thanks and likewise bro!
Eric - HAHAHA YUP!
I have a "custom" girdle exactly like that![]()
Wow...
I'm surprised this didn't happen to mine but I also didn't dd it or run aggressive timing.
WOW!!! Thanks for sharing. What did the combustion chamber and spark plug look like? Any signs of detonation?
Jeff
Eric - LOL! Where is your [photo] trophy?!
Jeff - My pleasure! I tried to snap some meaningful pictures to document and answer those questions:
Cylinders six, four, and two per request. That NGK copper-8 is truly "non-projected" now lol. You can also see one compression ring caught in the intake valve.
Cylinder #6's combustion chamber. The other five pistons and chambers are normal.
Piston #6 aka my new coaster - HAH!
I needed to toss in a "nice" picture among the numerous bad ones.
Even though engine carnage's like this are always sad I must say the autopsies are really interesting. Thanks for posting the photos.
What were you revving to?
You seem to have a bunch of trophy pieces. Any ideas how both the top and bottom of the piston got beat up so badly?
Jeff
