Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 90
Thread: 19T + e85 too much for stock bottom?
  1. #61
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    Haha I sure hope that mine and Jeff's results are kept in mind for those looking to push a stock bottom daily! As stated, my OCI's were very clean each time with M1 15W-50, and it has really good ZDDP per their specification sheets and others' Blackstone analysis results. I should be inspecting all Clevite bearings tomorrow in regard to my tune, albeit I intentionally left it as aggressive as Mark's and my last build.
    Panda v.3 has officially begun. I have missed doing this stuff.
    A nice view before the teardown of the motor.
    Some Freddy Kreuger sh*t in here LOL. It also looks like the cell phone Decepticon was trying to escape.
    Cylinder #6's rod took out a good portion of the piston, the oil rings, AND the damn girdle to boot!
  2. #62
    Nov 2006
    Chula Vista SD, CA
    On that last note, I do have to say that Adam and Eric have been doing very well with their TD05/stock block setups lol! They each obviously have bigger plans in store though.
  3. #63
    JNS Engineering verified
    San Jose, CA
    Awesome carnage pics! Just curious - I know you're E85 now but how much power have you put down with a TD04 setup on 91 pump?
  4. #64
    My head hurts
  5. The Following 2 Users Say Thank You to Ray Pampena For This Useful Post:
  6. #65
    I'm surprised it got this far, did it not start knocking before the bomb went off? You said you were pulling in a high gear (4th?). Maybe it was preignition.
  7. #66
    Low & Slow verified
    Fortson, GA
    Did the rod bend or break? The carnage tells me it broke, the picture looks like it's still attached.
    Jeff
  8. #67
    Nov 2006
    Chula Vista SD, CA
    Jim - I replied back on NC3S! =]
    Chris - Good questions! We did two runs where I started in fourth. The video only shows the first spanking. After that, it was normal cruising for a good while without anything abnormal. TBH, I have not bothered looking at my MMCd auto-datalogs lol... probably should have used my GReddy RSS for the EMU's internal datalogging too. As for the rest, I should have it on the stand and disassembled today.
    Jeff - When I took a gander last night, I saw that the lower part of #6's rod was still connected to the crankshaft - shown in picture. The portion that connects to the piston/pin obviously raised hell before being spit out. The remainder did not look as bent, but I will post up more later when I tackle that cylinder first among the six.
  9. #68
    Low & Slow verified
    Fortson, GA
    Take lots of pics please. I'm curious to see the rod journal.
    Jeff
  10. #69
    Quote Originally Posted by bboyalan View Post
    I've been lucky, barely driven it, and stuck with race gas, lol. Can't wait to see what you come back with!
  11. #70
    I don't bite
    Southern IN
    Those pics look even worse than the mess I made with a stock 6g74 bottom end. Does look like the same result though...busted rod, crank, girdle, Tcase and bellhousing...correct?
