Results 1 to 3 of 3
Thread: Repalce headbolts or not.
    Oct 2013
    Replace headbolts or not.
    I have a 92 Dodge Stealth 3.0 SOHC with a probable blown head gasket.
    I looked through the Dodge Service manual and there is no mention of replacing the head bolts and they do not appear to be Torque To Yield specs anyway. Normally on most more modern engines I replace the bolts with ARP's but there are none available for the Mitsu 3.0's
    I am not a fan of the quality of parts store replacement bolts so.....
    Does Mitsubishi recommend replacement? Dodge service manuals don't mention it.
    Anybody make a better replacement bolts than OEM?
    Thanks in advance.
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    look at the 6g72 engine manual (5th link) Ninja Performance Shop Manuals
    start at page 19 for torque specs, page 21 has sohc engine cylinder head at 80 foot pounds
    there are arp head studs available for the 6g72, though it's a bit overkill on a SOHC; OEM is more than enough
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
    Andover, MN
    Quote Originally Posted by IMGTX View Post
    Thanks in advance.
    Most of the time the head gaskets go on the SOHC because the heads get warped. The head bolts on the SOHC are stronger than the DOHC. I'd reuse them.
