Results 21 to 30 of 32
Thread: Oil Pressure Issue
    Sep 2012
    Decatur, TN
    Quote Originally Posted by Hyperfocus View Post
    The good: The oil strainer did it's job well but was obviously blocked as a result. There's was just a few fine particles of bearing material in the pan and no heat marks on the rods/crank. I still plan to replace the oil pump, strainer, and bearings while I have it apart. God knows what they've been through. But on the bright side, this could have been MUCH worse.
    Might not be a bad idea to replace (or flush) the oil cooler while you're at it. If any of that got past the strainer and filter, oil cooler would've been the next stop. Considering how easy it is to remove it either upgrading it, or flushing it out several times with acetone and coffee filters wouldn't hurt just to be safe.
    Banned J. Fast's Avatar
    I'd pump the whole system down like I described earlier before you reinstall new oil pump gears and new bearings. Hopefully the filters on the pump are clean. Sucks the condition was passed on. Hopefully there's not metal contamination.
    Ann Arbor, MI
    OP - Post pics if you find anything! Hell, post pics even if you don't! More content on this forum is never a bad thing.
  4. #24
    New Member
    Oct 2013
    Black Forest, CO
    I do plan to go through everything in that area. Oil cooler, filter housing, etc will all come off and be cleaned just to be safe. I already have a new oil pump, gaskets, etc and bearings on the way. I've yet to check the turbos but if there's any sign of play they'll be pulled and rebuilt. Maybe even upgraded if I can find a decent source of genuine Mitsu comp wheels.
    I'll be sure to take some pics too. I haven't gotten even a minute in the shop since the warmest day this week was 0° without windchill. Yesterday was a balmy -10 in the sun. So once I can get under the car without risk of frostbite I'll be sure to update.
  5. #25
    New Member
    Oct 2013
    Black Forest, CO
    Finally got some pics! Oil pump gears were a little worn, but still in one piece. The housing was rebuildable so I decided to rebuild it rather than replace. The pan and sump cleaned up nicely too so those will be reused as well. Turns out the timing belt, pulleys, tensioner, and water pump are all brand new Mitsu stuff which was a nice surprise. So all together the 120k maintenance will be done early, and for just a few hundred bucks.
    My Clevite bearings showed up today so those will be going in soon, I'll post some more pics afterwards.
  6. #26
    New Member
    Oct 2013
    Black Forest, CO
    New rod bearings are in. The old bearings weren't nearly as bad as I expected, but the fine top layer was starting to shed and a few were starting to show copper. So it was definitely time for a replacement.
  7. The Following User Says Thank You to Hyperfocus For This Useful Post:
  8. #27
    Good choice, I was definitely satisfied with my Clevite's
  9. #28
    New Member
    Oct 2013
    Black Forest, CO
    IMO, Clevite P-series are the best street bearing you can buy. I ran them in my TSi for years under every form of abuse you can imagine and they were barely polished when I sold it. I killed numerous brand new Holset turbos and never even scratched a Clevite.
  10. #29
    Sep 2012
    Decatur, TN
    Thought about going with Clevites, but decided on King bi-metals for now. While they can't withstand as much load, I figured the deeper babbitt layer would help catch any debris that may come through during initial start up and stuff since I had a full rebuild due to metal debris bouncing around the engine.. After this year's light usage, shake down and tuning, I plan to replace them with WPC coated Clevites for long term usage.
    I've used Clevites in a handful of other engines (stroked 350 small block, 4.6 mod motor, and a basic 454) and have had numerous other problems and failures, but the bearings still looked pretty much new. Even the mod motor after 40k miles and blowing the motor up, the bearings looked good. This will actually be my first time using King.
  11. #30
    Spaceace60 verified
    Sep 2011
    Cranberry
    well worse yet I put a motor in that had less than 30k on it,perfect numbers on compression ect always had super oil pressure sent it to get tuned up ect ect it sat at guys house cpl mos when I went to bring it home motor sounded great but 0 oil psi?(thought it was gauge/wire?)got cpl miles dwn rd and spun middle bearing,towed it home and nxt day fired it up so I could make sure it wasn't just a lifter issue? well it had great oil psi,but it was deff spun bearing so why the temp lack of oil psi is still a guess? it was about 10 degrees the night it lost oil psi? any guess's as im rebuilding it and don't thanks Jim
