So I got the power distribution panel finished today. This panel will be mounted to the stock rear strut channel. It will be the only thing visible when the rear seats are down. this panel only have the power for the amps. Everything else will have power come through a separate fused block as I don't like feeding power off the same block/lines as the amps as it can caused voltage fluctuations in the lines. the capacitor is an old Blackmore 2 fared cap which will be more than enough reserve power for the two amps I have running.I have had this cap for about 10 years now and it looked like crap. So I wrapped in a CF vinyl I had which came out real nice minus the damn dent in the cap which I can't fix....
Left side is the fuse block, right side is the grounding block. Picture makes them look crooked but they are all mounted straight.
Rear speakers showed up today so I'll get them installed as soon as I can. Looks like we are going to get about 6" of snow tonight so I won't be able to get anything done the next couple days most likely...
