I know that there is another thread about this, but this is my actual own conversion in which I will try to find my way out of it.
the callipers that I bought are from a Porsche Cayenne S - 955 - front are Z18, so they've been designed to use 350x32 for fronts and rears with 330x28
more informations can be found on the other thread about these calipers and their specs.
I dont care at this point of brake distribution, as I will check that later and solve it if necessary with a proportioning valve.
that beeing said, I have followed, in this forum and others also, how others have done conversions by using oem parts.
there are many benefits from doing it this way, instead of buying and spending tons on some branded products that are actually chinese.
So, for the front, after searching over catalogues it all came to: EVO X vs 370Z front rotors, basically 350x32 vs 355x32.
BUT, the 370Z discs have a -5mm offset, than the 3kgt ones, so probably for some of you that wants to use the OEM 18" wheels it will be possible as the calippers will sit inside with more 5mm - will let you know about that as I do have these wheels also here.
The front Nissan 370Z front rotors fit, as it has been done before here: http://www.3sgto.org/3000gt-stealth-...rakes-3-s.html
I didn't received yet the front discs, as this would possible be in the next couple of days.
now, the biggest issue on doing this is with the rear brake rotors and offcourse with the e-brake.
The donour cars for rotors, EVO and 370Z - have 330x22 vs 355x22.
The rear Cayenne calipers are designed to use a 330x28 brake discs, which is a hard to find one.
I've been looking around for the 28mm discs and couldnt find an OEM disc that was designed to be used on rear and be that wide.
So, for the rears I need a 28mm or I can use the 22mm ones?
This is very important, because if I choose to go with a 22 one, I would try to solve the e-brake with oem EVOX parts.
what others did:
on other platforms like vw, audi, etc.. they went with 22 ones and currently live happy - no problems at all, at least not mentioned on forums.
If I decide to go with a 28mm rotor, I will have to go with a front evo7-8-9 rotor which I can find them in 30-32mm width, remove the ebrake components and install a parking valve(or how its called).
I couldnt found any mechanical calipers that will fit over a 22mm(Willwood, brembo). don't know about Audi electrical ones..
next week probably I'll check to see how the complete calliper with pads will seat on a 22mm disc.
