Results 11 to 20 of 25
Thread: ecu not working error code
    now i was getting error loading ftd2xx.dll when this error occured before so i googled where to download it and got it off a random site lol could that be the problem?
    Yes, basically. Since you didn't really give any insight into your issue other than linking to another thread and a trouble ticket that you can't see without a log-in...
    Maybe Greg can chime in.
    EcuFlash Version 1.44.3721
    OS Version Windows 7
    Qt Version 4.8.0
    63 memory models read.
    scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
    612 ROM metadata models scanned.
    checksum module "subarudbw" loaded.
    checksum module "mitsucan" loaded.
    checksum module "mitsuh8" loaded.
    patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
    patch module "Mitsu CAN RAM Parameter Logging" loaded.
    flashing tool "wrx02" loaded.
    flashing tool "wrx04" loaded.
    flashing tool "sti04" loaded.
    flashing tool "sti05" loaded.
    flashing tool "mitsukernel" loaded.
    flashing tool "mitsukernelocp" loaded.
    flashing tool "mitsubootloader" loaded.
    flashing tool "shbootmode" loaded.
    flashing tool "shaudmode" loaded.
    flashing tool "subarucan" loaded.
    flashing tool "subarucand" loaded.
    flashing tool "mitsucan" loaded.
    interface open
    J2534 API Version: 04.04
    J2534 DLL Version: 1.00.3721 Jan 9 2013 1759
    Device Firmware Version: 1.12.3688
    Device Serial Number: TA2OhU5r
    interface close
    interface open
    interface close
    interface open
    interface close
    131072 byte image read.
    using metadata XML ID 23862006 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/3000gt/23862006.xml
    interface open
    characteristics set to 0,8,1
    flush
    flush
    baud set to 9600
    flush
    set pin 0 voltage 17
    flush
    sending init sequence 2
    [W] 00
    J2534 error [ERR_TIMEOUT].
    set pin 0 voltage OFF
    interface close
    interface open
    flush
    flush
    flush
    [W] 00
    interface close
    I lack color... verified
    Aug 1998
    Try a different mini USB cable. The Tactrix uses any ole one.
    tried new usb cable error went away but still no flash.
    [13:06:07.658] EcuFlash Version 1.44.3721
    [13:06:07.658] OS Version Windows 7
    [13:06:07.658] Qt Version 4.8.0
    [13:06:07.665] 63 memory models read.
    [13:06:07.666] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
    [13:06:07.806] 612 ROM metadata models scanned.
    [13:06:07.806] checksum module "subarudbw" loaded.
    [13:06:07.806] checksum module "mitsucan" loaded.
    [13:06:07.806] checksum module "mitsuh8" loaded.
    [13:06:07.806] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
    [13:06:07.806] patch module "Mitsu CAN RAM Parameter Logging" loaded.
    [13:06:07.808] flashing tool "wrx02" loaded.
    [13:06:07.809] flashing tool "wrx04" loaded.
    [13:06:07.811] flashing tool "sti04" loaded.
    [13:06:07.812] flashing tool "sti05" loaded.
    [13:06:07.812] flashing tool "mitsukernel" loaded.
    [13:06:07.812] flashing tool "mitsukernelocp" loaded.
    [13:06:07.812] flashing tool "mitsubootloader" loaded.
    [13:06:07.812] flashing tool "shbootmode" loaded.
    [13:06:07.813] flashing tool "shaudmode" loaded.
    [13:06:07.814] flashing tool "subarucan" loaded.
    [13:06:07.816] flashing tool "subarucand" loaded.
    [13:06:07.817] flashing tool "mitsucan" loaded.
    [13:06:09.656] 131072 byte image read.
    [13:06:09.656] using metadata XML ID 23862006 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/3000gt/23862006.xml
    [13:08:19.322] interface open
    [13:08:19.334] J2534 API Version: 04.04
    [13:08:19.334] J2534 DLL Version: 1.00.3721 Jan 9 2013 1759
    [13:08:19.334] Device Firmware Version: 1.12.3688
    [13:08:19.334] Device Serial Number: TA2OhU5r
    [13:08:19.335] characteristics set to 0,8,1
    [13:08:19.336] flush
    [13:08:19.336] baud set to 9600
    [13:08:19.338] flush
    [13:08:21.030] set pin 0 voltage 17
    [13:08:21.042] flush
    [13:08:21.542] sending init sequence 2
    [13:08:21.542] [W] 00
    [13:08:21.543] [R] 00
    [13:08:23.544] set pin 0 voltage OFF
    [13:08:23.545] interface close
    Aug 1998
    Stupid question: do you have the ignition on?
  8. #18
    can you call me? instead of this makes it hard..
    i have the key turn to the on part.
    815-546-7233 please
  9. #19
    Aug 1998
    Sounds like you need to get in touch with Tactrix.
  10. #20
    worst company to contact.....
