EcuFlash J2534 Error Will not Read ECU Please Help - DSM Forums
this link is the same exact issue i am having.
https://tactrix.zendesk.com/requests/14361
this link is my trouble ticket with tactrix.
Let me know if you need anymore information.
Your flash cable secured properly, good connections, etc..
From all that i checked they are.... i unplugged everything checked all wires i am ripping my hair out man.....
just one day i get in my car to tune and bam this is my error of doom...
What happens when you do a "Test" write to the ECU with Evoscan. Maybe copy/paste the error message that you get.
J2534 API Version: 04.04
J2534 DLL Version: 1.00.3721 Jan 9 2013 17-24-59
Device Firmware Version: 1.12.3688
Device Serial Number: TA2OhU5r
sending init sequence 2
J2534 error [ERR_TIMEOUT].
interface close
What kind of setup are you using? Jester, adapter harness, etc?
Also, what year is your vehicle/harness.
jesters
car is a 91 and has 93 engine.
i have 91-93 jester ecu with his 91-93 harness that comes with the kit all is installed in right location.
yellow cable connect into pin 51 which is top left in that section correct?
I assume you already have the CAS worked out.
I didn't know the jester ECU used a harness. Anyways, make sure the flash wire is secure in every connection possible. In my personal situation, the pin that connects to the ECU wasn't quite making good contact with the ECU and that gave me the following message:
ummm i dont understand your post other then make sure the yellow connecter is mated well..
