Results 11 to 20 of 30
Thread: Low Compression Results (Help Diagnose Please)
    Warner Robins, GA
    You said you didn't check the crank timing mark? The crank timing mark is just as important as the cam marks, so I would check it also. You said it idled and ran okay last time it was running, right? If that is the case, the engine should be okay. I would zero the timing, then re-check the compression. If the compression comes back to something reasonable, then the rings/valves/etc are not bent/broken. Quick, cheap way to check current status of engine internals without full disassembly.
    I have had more than a few cases of timing belts getting loose. Most recently, I had a freshly built motor act just like yours. Timing belt had come loose and slipped a tooth. After resetting timing marks and re-tensioning the belt, engine had great compression and ran fine. Just sayin'.
    Its possible your tensioner collapsed and caused the issue.
    +1, sounds like a bad tensioner.
    Quote Originally Posted by BlackSpyderVR4 View Post
    I know if you start the car it should tighten up the belt, but I just don't like that much play.
    Oh and DO NOT start that car until you fix that belt/tensioner.
    I don't bite
    Southern IN
    Put the crank to TDC, then look at your cam gears.
    And like everyone else is saying, reset timing and check compression.
    To reset the crank, I just need to remove the plastic shield, wheel, and balancer and I can crank it right? If I have to pull the motor mount, etc, I just don't want to do this in my apartment parking lot. I will fill a lot more confident doing this in my garage once i move in.
    Pretty much, but You will most likely need a tensionor just to get it sort of safe to start. If you don't know how to set time or much about it then I don't recommend you doing it in a parking lot. If I had a dollar for every guy that screwed up their 3s timing I'd have a 3sec car.
  7. The Following User Says Thank You to green-lantern For This Useful Post:
  8. #17
    BTW if you mean "crank it" as in letting the starter turn the engine then NO. God stop! before you destroy poor engine.
  9. The Following User Says Thank You to green-lantern For This Useful Post:
  10. #18
    I don't bite
    Southern IN
    You are in TX, plenty of members in the state that can help you or point you to a good shop that can. That would be the direction I would suggest at this point.
  11. The Following User Says Thank You to familyMAN For This Useful Post:
  12. #19
    By cranking no I was not referring to the starter. Im talking about turning the crank 1 tooth from TDC by hand so I can realign all the timing marks correctly. I know how to reset the timing have done it several times on other cars and pretty sure I did enough research on this car to be able to reset the timing on the VR4. But at this point in the game I should just wait to I move to the new house. I will probably just flatbed the car to the new house. Because Im redoing the 60k service. I know the previous owner redid the water pump, but i just want the peace of mind knowing it was done right. What I could use is help me start compiling a list of things I need for the rebuild.
    Pistons:
    Rings:
    Pins:
    Rods:
    Bearings:
    AC Delete (New Belt):
    ABS Delete:
    Timing Belt:
    Water Pump:
    Oil Pump (Maybe???)-
    Tensioner:
    Wires/Plugs (Good Spark Plug for 450-500WHP??):
    Gasekets:
    water meth kit:
    Head Lift Fix (Should I????)
    So Ill be taking suggestions on parts and where to get them. Im in the process of digging all around the online shops. But I do not have near as much time in this platform as you gentlemen.
    All the stuff I already have from page 1:
    Aftermarket Parts:
    Fuel Loop
    3SX Custom Fuel Kit
    Tanabe CBE
    Aftermarket Boost Gauge
    Light Weight Flywheel
    Spec Stg 1 Clutch
    99 Lifters
    DP
    EGR Delete
    Krank Vents
    LC-1 Standalone
    T-Case Bracket
    Solid Motor mounts (not installed)
    Cloned ECU
    482 EVO MAF
    Mishimoto Performance Radiator w/hoses
    550CC Lucas Injectors
    Walbro 40 E85 Fuel Pump w/hotwire (not installed)
    Dual Core FMIC
    Hallman MBC
    TB rebuilt by April
    S15 Billet Turbos (not installed)
  13. #20
    your one hour south of Dynamic Racing in Alamagordo,NM . just take it there and be done with it. Worry free
