I took the car to the track about 2 weeks ago and it ran a 13.9 at 3,500FT. Car was running good. Fast forward to a week ago, I was coming off a light accelerated, and hit 10 or so psi. I heard what sounded like a pop and a release of pressure, pulled over checked everything over and car was idling fine, limped it home and noticed it wouldn't boost over 3 or so PSI, no stuttering, no jerking, no smoke, it just felt like it was being powered by a 1.8 4 banger if that. Car pulls 18-20 PSI Vac, and idles 100% fine. I checked all couplers and they all appear to be solid. Decide to do a compression check here are the results (All were on cold engine, was preping the engine to put the upgraded turbos on, but I think I have a bigger problem then what i origninally thought was just a popped coupler):
1-72
2-92
3-89
4-90
5-92
6-87
I had the car hooked up to my Ram 1500 so battery is not the problem. Bought another compression tester….read the same. Manifold was off, so it is not the throttle being open. I cranked it 10+ times. I'm almost 100% i executed the compression test correctly.
I checked the PCV valve-Rattled everything appeared ok. Check timing marks everything was +/- tooth. Put oil in each cylinder, pressure raised by 5-10PSI (cold engine). I have been told if it was bad rings it would increase at least 40 or so PSI. I'm probably going to slap everything together and pressure test on a warm engine. After hours and hours of research all I could find from guys experiencing my same issue on other platforms is either a) did not open throttle during compression check (I have the manifold off, so this is not it) b) Bad rings (but all 6???? at same) c) Valve timing/bent valves (timing marks were dead on). Build list is below:
Aftermarket Parts:
Fuel Loop
3SX Custom Fuel Kit
Tanabe CBE
Aftermarket Boost Gauge
Light Weight Flywheel
Spec Stg 1 Clutch
99 Lifters
DP
EGR Delete
Krank Vents
LC-1 Standalone
T-Case Bracket
Solid Motor mounts (not installed)
Cloned ECU
482 EVO MAF
Mishimoto Performance Radiator w/hoses
550CC Lucas Injectors
Walbro 40 E85 Fuel Pump w/hotwire (not installed)
Dual Core FMIC
Hallman MBC
TB rebuilt by April
S15 Billet Turbos (not installed)
Any help would be greatly appreciated,
Mike
