I've been fighting the installation of crankshaft thrust bearings for the past day. I can't seem to get the clearance within the manuals' spec of 0.05mm-0.25mm. One side is 0.06mm and the other is under 0.04mm. I followed the method described by Ray below and can get them set where I want them, but they move back after torquing the cradle. Any suggestions? (I can't be sure of the tight side because 0.04mm is the smallest my feeler gauge goes)
"on engines with a top and bottom thrust you have to "set" the thrust. tq down the cap with the thrust washers in then crack the bolts loose. take a soft mallet and tap the crank forward and rearward. this aligns the main cap and makes the crank ride the upper and lower washers evenly. your just tapping here.. not smashing and wrecking things. then check to see if you have the propper thrust. there are many tricks to building good engines"
-Ray Pampena
