as promised, i am moving my alternator how-to thread from 3si to 3sgto!
so here ya go!
Tools you will need:
- Jack
- Jack Stands
- A 4-way
- Some Extensions
- 10mm Socket
- 12mm Socket
- 14mm Socket
- Anger Management
Now first thing is a tuffy. jack up the car and take the drivers side wheel off.
it looks like this...
once the wheel is up and off, you should then start removing the bolts that secure the a/c line that runs from the compressor to the drivers side of the car and around to the back of the engine. there will be two 12mm bolts towards the front, and on the firewall there will be two 10mm nuts as shown below...
12mm by the headlight bucket.
12mm nut by the a/c fuse box.
two 10mm nuts on the firewall.
once youve taken those nuts/bolts off, the line should move around pretty easily. you should then tie up the a/c line to the hood. (your hood shocks need to be good for this)
i used some spare speaker wire.
now its time to take off the accessory belt off. show below is the tensioner. what you will need to do, is loosen the 14mm bolt that holds the tensioner in place. (just loosen, dont remove the bolt.) once you have the 14mm bolt loosened, theres a 12mm bolt that faces the top of the car. simply turn that bolt counter clockwise to relieve the tension of the belt. once its loose enough, just pull the belt off and mark which side was facing the outside only if you plan on re-using the belt.
before we go any further, we have to make some... "wiggle" room. all you have to do is simply remove/loosen the radiator support bracket bolts on the drivers side.
