Results 1 to 10 of 10
Thread: Na motor to tt motor swap out
    Sep 2013
    2012 April
    So i was wondering how easy it is to swap out a na motor for a tt one? I was originally doing the tt conversion however my motor has low compression and a miss so its no longer worth it.
    What are things i will need? Like motor mounts, ecu, harness? Anything else? Is it easy? Also is anyone trying to sell any of the parts i just listed?
    My car had been a huge pain for the past year and any advice would be really appreciated.
    ill sell you my engine.. read my signature... make me an offer
    2013 Yamaha R1
    2003 Honda CBR600RR
    Evo X 2008
    Blue 1995 3000GT NA
    *Performance: Test pipe, OBX headers, Custom Single Exhaust, TT Plenum, TT fuel pump, 272/272 cams, VR4 2nd gen heads, 3rd gen lifters, Under drive pulley, Slotted Drilled Rotors, Rear and front solid motor mount, Intake 11.5inch Spectre air filter.
    *Weight: 2930lb
    *Electronics: AEM UEGO wideband, Evoscan, 99 Flashable ECU, Tactrix 2.0.
    WHP~231 WTQ~207 VDR Dyno http://i70.photobucket.com/albums/i1...ps03a88b79.jpg
    I don't bite
    Southern IN
    Everything bolts in. If you go turbo, you'll want an ecu, injectors, injector resistor pack, and FPR.
    I don't bite
    Southern IN
    Sent you a PM. I'm in IN also. Maybe I can help you out.
    Sep 2013
    2012 April
    No sorry let me rephrase my question, what do i need to drop a tt engine into my car? Tt motor mounts? Harness and ecu i know but what else?
    The actual motor mounts are the same. The front motor mount bracket is different on the TT to clear the front turbo.
    Sep 2013
    2012 April
    So just the front bracket is different? So i can keep everything else? Is there any modding to fit the tt front bracket? Or does it go into the same place?
    The bracket bolts to the block.
    Sep 2013
    2012 April
    Thanks exactly what i wanted to know! Ok i have a fwd 5spd so will the flywheel and clutch back up to the motor? Because doesnt the tt car needs a special flywheel, or is that just because of the tranny and it doesnt matter for the engine? Thanks!
    Never finishes any verified
    Wake Forest, NC
    You will need the full TT block including the TT front mount, TT wiring harness and ECU, SMIC's, Oil cooler. Depending on the car you will need to wire in the front O2 on the TT engine as the N/A engine bay harness does not have the wiring for the front O2.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
