Where I'm at. 13t's on temp hiatus, so 9b's it is. As it is I can only get 91 oct as the highest grade of gas I can get other than the e85. So as you can imagine I'm worried about detonation with the 91. On 91 what would be a safe boost psi range without injection and is there one? Or just go e85 and not worry about it.
To me pros water injection
1 not bad for engine
2 cost starting about 400
3 water and rub alcohol cheap
4 higher boost
5 basic simple setup
Cons
1 always having to maintain extra fluids
2 still buying exspensive gas
Pros for e85
2 cheap
3 no worries about reasonable boosting
Cons
1 buying another set of injectors, new fuel pump, fuel filter, and not bad but buying flash ecu for mapping
2 not available everywhere
3 bad mileage
4 no worries about over boosting
