Results 1 to 7 of 7
Thread: OBD2 Splitter
    Jun 2011
    Sweden, Gothenburg
    OBD2 Splitter
    Is there any problems running a OBD2 splitter for our cars? Like this OBD2 OBD II Splitter Extension 16 Pin Cable Male to Dual Female Y Cable Adapter | eBay
    Would be nice to have the lcdboostcontroller connected at all times and not have to swich around when I want to use a datalogger. But maybe signals will interfere??
    Aug 2011
    Won't work. The scantool (or LCDBS) maintains active communication with the ECU. Those cables are meant for passively eavesdropping on that communication. Bringing a 2nd active device into the mix would crash the logging session.
    I thought the LCDBS had a datalogger passthrough though? It talks to the ECU and then mirrors the data out on a 2nd port?
    Jun 2011
    Sweden, Gothenburg
    Quote Originally Posted by Jeff V. View Post
    hmm yes it has a cable that ends in a vga connector for that. But I don't think EVOScan will work with that? (only tactrix cable?)
    Is there any other good datalogger that will work?
    Oct 2011
    Sundsvall, Sweden
    You can actually use the EVOScan with the LCDBC using the pass through option and a FTDI-based USB-to-serial cable. Ask Antero and he'll give you the details.
    Jun 2011
    Sweden, Gothenburg
    Quote Originally Posted by Unlogic View Post
    Oh really didn't think EVOScan would work without tactrix. Will use that then. Thanks!
    Is this the same cable you use to update the software in the BSLCD?
    Oct 2011
    Sundsvall, Sweden
    Well both yes and no. Any decent USB-to-serial cable will work when you update the firmware of the LCDBC. Evotune on the other hand does only support FTDI based USB-to-serial cables.
