Results 1 to 10 of 14
Thread: Jbl ms-8
    Jbl ms-8
    I was certain that there is a member here that uses one of these, hit me up if you read this please.
    I do ..
    I am thinking about dropping my AudioControl Digital x-over (3-way) and Digital EQ (6 channel 30 band + 2 channel para-band) plus all my amps but sub. and use this for:
    Amplifiers (front door, front dash, center, rears)
    Timing Alignment (same channels + sub)
    EQ (same channels + sub)
    I have a Pioneer DVD player with the 5.1 DTS external brain, so I do not need the Logic 7.
    with your experience do you think that the MS-8 will work for me?
    I'm only using the ms-8 to drive my smallest speakers mids and tweeters . door speakers are amplified because I felt the ms-8 didn't have nearly enough power to drive them. and the sub of course is amplified. (active 3 way front + sub, no rear speakers)
    JBL ms-8 only wants one pair of rca ran as an inputs
    (it has 8 inputs but it can only handle 2 input channels at a time)
    many people assume when they see it have 8 inputs that it'll be able to handle all 8 separately but thats not possible. so I don't think it'll work for you
    will have to contact JBL, I am thinking that it is just two channels so you can use the Logic 7.
    yep ms-8 is only a 2 channel input system.
    I run the JBL MS-8. The way it works is you provide signal from your deck to your ms-8 via 2 channel. Then the jbl ms-8 does time alignment and runs all your speakers active and if you have a center channel you could run Logic 7. The JBL MS-8 only has about 30 watts per channel so your not talking a whole lot of power. I would recommend keeping you amps and running them from the rca outputs out of the ms-8 to your amplifers. Let the jbl ms-8 run all your speakers crossover settings and time alignment. If you bypass the JBL MS-8 by running only certain speakers off of it and then a signal wire coming off the radio to another amplifer bypassing the ms-8 those speakers will have a 3millisecond delay. I can hear it and it's talked about in the manual. The MS-8 is a awesome tool if you know how to use it correctly. You can not adjust from your radios eq any longer you would want to leave that on flat so it doesn't throw off your base tune. It's the best tuning device for a car audio system if you don't have access to a RTA.
    i don't think anyone would bypass the ms-8. fwiw all my speakers are controlled by the ms-8. ms-8 does all my EQ, crossover setttings and time alignment..
    its just that some speakers are driven and controlled by the JBL MS-8 and some speakers are driven by an different amplifier but still controlled by the jbl ms-8.
    I would just turn the logic 7 off not bypass everything
    but the amp portion is to small in wattage so I am going to pass.
    hold the bus, what speakers are the MS-8 driving....what is their ratted wattage...the speakers that is.
