I couldn't start the vr4 recently without charging the 2 year old battery, so I took it for a spin and took note of the voltage reported by the scanmaster (~13.5v). I replaced the battery and cleaned the terminal connections (they looked good, now they look perfect). With the new battery, once on the road, I saw 13.8v... by the end of a short drive it was at 13.6v. A similar gauge on my frs reports 14.4v... did my original alternator finally wear out? Think this could be related to the little bit of break-up/blow out I recently started noticing at high boost/rpm? Stock ignition system. I'm hoping I can replace the alternator to avoid breaking the seal on my intake system![]()
