Results 1 to 10 of 10
Thread: Snowboarding
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Snowboarding
    Any of you guys snowboard? I have done snow skiing every time we've gone out on the slopes but I am thinking about switching it up. I wakeboard in the summer and I have no problem with that - are the skills somewhat transferable? Everyone else on the trip will be skiing so I don't want to try the snowboard and be falling/going terribly snow the entire time.
    Wut wut? verified
    New Berlin, WI
    I've been snowboarding for 20 years and have a couple of years teaching experience too. I'd say give it a try. People either get "it" in 30 mins, or get it in 3 months. If you still suck after an hour, return the board and stick to skiing If you have a friend that snowboards, they should be able to give a few tips to accelerate the learning curve.
    I haven't wake boarded, but have water skied a lot. When I started snow skiing, not a lot transferred. The weight/balance is completely different. AKA being towed vs letting gravity do the work. Also snow has a lot less friction than water.
    One fix at a time verified
    Kansas
    You should pick it up after your first day. For the first few hours you'll be falling down left and right. My knees and butt were beat red but you'll reach a point where it all "clicks" and makes sense. I didn't take any lessons because I'm a quick learner and I did skateboarding when I was younger. I never went wakeboarding before but I'm sure some of the skills will transfer. You use less ankle movement but more of your whole body leaning in to turn. Don't be afraid if you feel like you're leaning so much you'll fall over. Once you get over that you won't fight it as much and can naturally go with the flow as you turn.
    I know I had more fun snowboarding than skiing because it was a greater challenge. I've only been 8 days total over 2 years but I got enough confidence to take black diamonds as long as I stayed out of the moguls which tear up my balance if I'm not switching back and forth through the turns. Skiis are a little easier to conquer those with. Make sure you get a good rental board and have everything set right. We had one friend that didn't know if he rode goofy or regular. After he mentioned he spent more time goofy I reset the angle of his boots and it was like knew how to snowboard all along. Make sure the back is tight against your boot or else you'll struggle turning and in general balancing going straight especially at higher speeds.
    I'll be going back to Colorado in Feb. It makes a huge difference who you go with. Had it not been a good group of friends I don't think I'd go every year.
    2004/5?
    SW Connecticut
    BEND YOUR KNEES. You pivot over your leading foot, don't be afraid to lean down hill, the biggest problem I've seen beginners have is leaning back when transitioning edges as if they don't want to go down the hill. Bend your knees.
    Sent from my Motorola Atrix
    ~2006
    I think I am going to see if I would be able to trade in the snowboard for skis if I didn't like it. If so I think I am going to try it. If it is miserable and everyone is waiting around or blasting past me then I can go back to skis. We will be there for a few days so that is helpful, too.
    I like wakeboarding a lot better than water skiing so I think snowboarding will be more fun, too.
    I'm not scared of falling a lot (as long as I don't slam a tree haha), one of my biggest concerns is how I will get around on the flats. I finally rented a set of poles last year so with skis it was awesome lol I guess practice makes perfect
    Any tips for setting up the board? Will they help me at the rental place? I am a decent idea how I like my stance from wakeboarding but not sure how it translates to snowboards.
    Kansas
    They can be helpful. Sometimes you can find a younger guy working there that's more into it and can explain what everything does better. Most usually ask you to stand in a comfortable position like you're on the board, they'll take a quick look at how straight your feet are, and set the bindings. That doesn't really seem to work for everyone though.
    Here's a few good videos to familiarize yourself with some of the different settings. It all comes down to what you prefer and the best thing to do is go try it out to see what you like and don't like. Every person will be different. Settings can definitely make a big difference in comfort and ease of riding.
    Burton Snowboard Binding Setup - YouTube
    You can go browse the snowboarding forums for some great info. I spent some time over there before figuring out what gear I wanted to buy.
    Wut wut? verified
    New Berlin, WI
    Lots of theories/preferences on binding setup... I'll give you somewhere to start.
    For little kids you tell them to relax their legs and you lift them up, set back down and see how their feet are aligned. From there I turn each binding 1-3 degrees towards the tip of the board. Finding out if they are regular or fakie stance can be interesting... you should already know that.
    I'm -4 on the back and +8 or 9 on the front. A lot of guys prefer closer to -10/+15. Guys that ride switch a lot should be straight up - no bias towards the front.
    I think more important is making sure the rear of the boot is making good contact with the back piece of the binding.
    youtube learning to snowboard. the pros will tell you everything you need to know. best way is to start with one foot on the board and push with the other (like skateboarding on snow). work from there. i went snowboarding for the first time last winter. i don't think it's terribly difficult...and even my wife (who has only skiied in the past) was able to get the hang of it for the most part. we didn't even have an instructor...though it might have been nice to have one. we did stick to the baby slope the whole time though.
    Mad JDM Tite
    STL
    Here's my 2 cents for what it is worth as I have done both:
    1 - You will fall, especially when you start to get tired. It's easy to catch on offside edge when fatigue sets in and falling that way sucks. You may want to see about using a helmet just to keep the headaches at bay. Also watch your wrists. Falling forward onto your knees and catching yourself with both hands wears on your wrists
    2 - Exiting lifts is tricky as one foot is not strapped in, so riding alone your first couple of times is a good idea. This way you don't have to steer around someone when you exit or worry about fallling into them.
    3 - Incline is your friend. Having a slight incline helps with getting the hang of the balancing and transitions. I recomend finding a decent green run to learn on, it will be more fun than hanging out of a rope tow bunny slope.
    4 - Skiers get poles, you have have to unstrap and push. This makes certain runs less than fun on a board. When I was at Snowbird this really got old when I would go from one side of the mountain to the other. Try to avoid these runs.
    5 - The feel of boarding >> skiing imo. Because the lean involved with snowboarding I found the whole experience to be more fun that skiing. Going down the mountain became less about speed and more about the feel.
    I took to skiing very quickly, boarding took more time. If you can ski and have ever tried skateboarding you can figure out snowboarding.
    With regard to renting gear, the upside is that most resorts will only rent step in bindings for boards now which reduces strap in time and the mistake of not strapping in with your boot in the right spot. Also I have found that when renting equipment you should always ask for an intermediate or level II setup when possible. The gear is better which at the very least means more comfort.
    A lot of good tips and tricks here.
    For me, I miss it, a lot.
    I used to ski, then when I hurt me knee when I already had a ski trip planned. It had just healed before I the trip and my doctor recommended I tried snowboarding as I would have less of a chance of twisting my knee. So I did and I was hooked. (I was 15)
    From there on I would go on at least 2 trips each year, had my own board and loved it. Then I turned 18, went to college and couldn't afford it anymore. Back when I was 15 - 18 and had basically no bills I had all sorts of extra money from working.
    Now I'm 32 and my board has still not been used since I was 18. ... I need to change that.
    Have fun! You will love it. In my experience it was easier to learn the basics of snowboarding than skiing, but it was easier to get better at skiing than snowboarding.
  • History
  • Information
  • Groups
  • Events
  • Resources
