Results 1 to 10 of 10
Thread: Fuel trim issue
    Apr 2013
    Orlando, FL
    Fuel trim issue
    My fuel trims are in the negative. I followed this procedure "low trim is 94mhz and below so if your need to take away from the numbers in the 100hx cells and below. If they are positive, you need to increase the numbers". But when I do that my trims go way off -12.5. But if I do the opposite my trims come into spec? Is there something wrong here? Thanks for help in advance.
    Apr 2013
    Orlando, FL
    Using flash ECU
    Oct 2010
    St Louis
    Do both front and rear trims go negative or is one negative and one positive ?
    Sent from my SPH-L720 using Tapatalk
    www.ClonedECU.com
    The home of the Original Clone and Clone2 ECU!
    More Plug n' Drive and less Plug n' Fail like the others!
    Remember, if it's not a Clone, it's just a copy!
    Get Chromed!
    Donate Now and receive a coupon code for the amount of your donation (up to $50.00 US) which you can apply at check out for a Clone2 ECU, Plug n’ Play Harness, or Clone2 Plug n’ Play Package!!
    1999 3000GT VR4
    Glacier Pearl White
    Yeah it's stock . . . trust me
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
    Apr 2013
    Orlando, FL
    The rear low trim is within spec, its -1
    Apr 2013
    Orlando, FL
    Yes everything is negative. Evo Maft
    I lack color... verified
    Aug 1998
    Quote Originally Posted by FloridaVR4 View Post
    That's odd... I guess if the trims are happy then that's all that matters.
    Apr 2013
    Orlando, FL
    Well it was coming into spec but now it changed back to -12.5, I guess I will stick to the procedure. But is there any way to speed up the process? I got 16G turbos, 750cc injectors and an evo maft. Thanks again.
    Aug 1998
    Oh I'm sure the timer can be farted with but I don't know how that's setup. It's in the OBD2 section of the ROM.
    Apr 2013
    Orlando, FL
    That is not what I really meant. But the numbers on the right column in the maf smoothing (VE) table do you change the numbers separately or all together in %?
    Aug 1998
    To change just the low trim, you need to change all the % values from 100hz and lower as a group.
