Does anyone have experience with the OBD1 evoscan cable and using evoscan?
http://www.evoscan.com/evoscan-gps-o...i-/-aldl-12pin
I have it...but I ordered it 1 day before I found out I have a lower bearing failure..so it will probably be some time before I will be able to test it out. Hopefully it wasn't a waste of money. Maybe you could test it for me? haha...of course returning it after the results.
91 R/T TT
I'm not running their cable, but I do use evoscan with obd1. I have some old school serial cables and I just use a usb-serial adapter. I'd go with their cable as the adapter you need (if you have an old serial cable) is a PITA to get. I think I went through 3 adapters before getting the right one with some kind of special protocol.
what are your experiences vs say HHH
I could test this out the next time that I see an OBDI 3/S since I have the cables+software for all years. They are pretty much the same deal when it comes down to it, however, EvoScan already incorporates audible alerts and is set up for wideband input. HHH is more user-friendly in presentation IMO.
I have three as well man... LOL! Luckily, two of them are actually being used.Originally Posted by Hans@GZP
