ok, that kind of message should not happen.
Do you recall what you did when that happened? What page(people, events, vehicles,...) and what you had entered before it did that?
It happenend on the vehicle page and then again on the event page. After trying each option again I have not had the issue repeat. I could try wiping all my entries and starting over to see if that makes a difference.
And the totals page still fails to load for me. I get the "done with errors" note in the bottom right of the browser window and then the load screen just keeps running.
Levi, what OS / browser are you using?
You're using IE 8 ......
yes not using IE8 will get around the issues.
that said I need to fix it for IE8. So thank you for finding the issue.
Levi, Can you try it now? It should be more IE8 friendly now.
Everything worked, totals page included. I still get the "loaded with errors" note in the bottom left of the browser but everything looked fine.
I removed all my entries and then re-entered them. I did not experience any error messages like when I originally tried.
The one thing I did find is that the site does not prevent multiple entry on events. I was able to register the same driver for go karts and I was able to register the same car and driver for the road course, selecting the same class each time.
Oh and I did not see any class information aside from what was there previously for road course. Wanted to mention this in case you made changes.
cool clad it worked for you.
I have the car/driver check on my todo list.
