Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Are the trans to block plates interchangeable?
    Medford OR
    Quote Originally Posted by DK77 View Post
    My guess would be that it's primarily to shield the bellhousing from debris as well. I think I'll be ok as the newer one has more clearance than the older one.
    Here is the newer plate laid over the older plate.
    If you have a 4 bolt motor, it's a moot point... The older version wouldn't fit.
    Jan 2012
    Arizona
    its just a dust shield, there are a few gaps it fills, without it debris could get in the bell housing
    1993 VR-4
    Engine -
    IPS catback
    Custom Downpipe
    Custom FMIC kit
    Suspension -
    BC Racing coilovers
    Solid / Poly busings
    Feb 2011
    Scottsbluff, NE
    Yeah I have a 4 bolt. So the earlier one won't fit on a 4 bolt? Would the later one fit on a 2 bolt?
    1995 Dodge Stealth R/T Turbo
