If I'm running a blow threw and my IC pipes are 3 inch from the intercooler, what is the optimal size maf to use?
I would say the 3", GM part #25180303 IIRC.
Yeah I ran a 3.5 before but I just didnt like the way it looked
3"...
I run a 3" GM Maf on 3" piping and it works great, they don't like step changes as it disturbs the airflow making it difficult to tune..
Before the Dejon website went down he stated the 3.5" GM MAF was optimal and had least problems for blow thru.
The 3.0 maf with the after market billet ends will out flow the 3.5. Just an FYI.
Much cleaner looking set up as well.
Mods
2ND place Autocross NG09
Is it required to get a maf with the mesh screen intact?
CAUTION: Over Boosting May Cause Accidental Orgasm.
1993 Mitsubishi 3000gt VR-4
I would, it linearises the airflow going through the MAF. Will make readings more consistent which is always a good thing!.
