Results 1 to 10 of 25
Thread: DIY front splitter...
    Banned J. Fast's Avatar
    I started by measuring the inside track on my GT and cutting a notch in a piece of Econolite Paneling to fit between the wheels.
    I measured the distance from the front bumper to the firewall and cut a notch that depth.
    Then I scribed the front bumper contour onto the Econolite panel.
    After scribing the bumper I took a compass to the scribe line and added 2" to the sides and 4" to the front and then blended them.
    Then I built a jig of what I wanted the splitter to look like.
    Here's my jig. As you can see it has roll ups on the wheel wells and where the timing cover and end cover panels can be attached to enclose the entire undertray.
    Last week I visited Plasticare Inc. and purchased 3 yards of 5 mil carbon fiber and 1.5 yards of high density carbon fiber. I also purchased another System Three Epoxy Kit.
    This is the carbon and resin I'll be using.
    Structural Resin Epoxy for structural anchoring...
    Resin Epoxy Main body, end fences, and fender flaps
    The resin takes about 24 hours to dry at 70 degrees.
    Back to the jig... It's Econolite so I can paint form release on it and use it as a form to vac bag my splitter.
    I laid it up this afternoon... mmmm
    Now... go make one LOL!
    Dad verified
    01 Apr 03 - Jokes on me
    NJ
    Awesome. Just curious. What was the approximate price tag on this DIY?
    If you wanted to just use the econolite panel for the splitter $100.
    Carbon fiber and epoxy resin was $135.
    Sundries, sandpaper, and buffing wheel $40
    Approx $200 in materials to make the splitter.
    Sorry, also forgot to mention the 3/8" Hexweb cellular core was $30.
    Very nice, I can't wait to see the finished product!
    Great info! Interested to see the results.
    Hmm, I wanted to build up the thickness of my al splitter to make it look better. I wanted to add a lightweight sheet of something and glass over. Which would you recommend? What is the hexweb cellular core?
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Your awesome. Would you mind if I came to live at your house with you?
    To build up the thickness I use Hexweb cellular core. This is aircraft grade core. It comes in every thickness imaginable from 1/16"-2". An entire 3/8" nominal 4x8 sheet weighs like 15lbs. Once you sandwich it between carbon or fiberglass it's unbelievably rigid and strong.
    Another option is Nomex Honeycomb. It just all really depends on if you're contouring or flat forming. This example is from Fibre-Glast Developments Corporation. It's about $8per sf.
    There's a number of ways to sandwich or build layers as you know. Most carbon fiber pieces are only one layer of carbon over fiberglass matte/fabric. For aero parts its best to sandwich with carbon fiber or kevlar over a structural core.
    Dad verified
    NJ
    You should do a Group Buy on these. I'd imagine there would be interest. If I wasn't broke, I would be.
    wheatfield, IN
    whats your lay pattern going to be? i.e. 0 45 90 45 90 0, or 0 90 0, just to save weight
  • History
  • Information
  • Groups
  • Events
  • Resources
