www.fairtax.org
If you know anyone good at welding it would be worth getting a bead welded between the hub and friction plate if they could do it without distorting the metal?.
I'm pretty sure it would warp. I would think it would change the temper of the metal also.
Bobby, I know somebody mentioned it already in this thread but make sure to use a jack or hoist (or both) to put the trans in so you don’t risk bending the disk. Knowing you, you might be putting the trans in by hand you big sexy beast.
I am
It's interesting to see that pretty much all the solid hubs throughout every manufacturer seem to be identical... Wondering if the rivets might be too then.
I've had some fun with SPEC clutches that did the same thing.
