Results 1 to 4 of 4
Thread: AFR calculator program
    Hey watssup
    As an assignment for my java programming class.. I did a program that calculated AFR with the formula that monochrome stated.
    NMAFR = DAFR * MAFR / AAFR
    To calculate AFR value for your tune. Just one single AFR value at a time. You could do this in excel as well.. is a fairly simple program or function.
    You need to java JAVA environment installed other than that is not gonna work... i think.
    http://java.com/en/download/index.jsp
    This is the code in case you think I am being sneaky and sending you a virus:
    import javax.swing.JOptionPane;
    public class desiredAfr {
    public static void main (String [] args){
    double mafr;
    do {
    mafr=Double.parseDouble(JOptionPane.showInputDialo g("Enter your fuel map AFR: "));
    double aafr=Double.parseDouble(JOptionPane.showInputDialo g("Enter your actual AFR: "));
    double dafr=Double.parseDouble(JOptionPane.showInputDialo g("Enter your desired AFR: "));
    double nmafr=(dafr*mafr)/aafr;
    JOptionPane.showMessageDialog(null, "Your new AFR value: "+ String.format("%.2f",nmafr));
    while(mafr != 0);
    https://www.dropbox.com/s/hnj4gqnery...Calculator.zip
    This is my dropbox link.. when you hit download it might ask you if you really want to download it.. it looks risky.. it only says that because I am sending you and Exectuable file... do not click on discard..just click on the litthe arrow next to it and click: keep.
    2013 Yamaha R1
    2003 Honda CBR600RR
    Evo X 2008
    Blue 1995 3000GT NA
    *Performance: Test pipe, OBX headers, Custom Single Exhaust, TT Plenum, TT fuel pump, 272/272 cams, VR4 2nd gen heads, 3rd gen lifters, Under drive pulley, Slotted Drilled Rotors, Rear and front solid motor mount, Intake 11.5inch Spectre air filter.
    *Weight: 2930lb
    *Electronics: AEM UEGO wideband, Evoscan, 99 Flashable ECU, Tactrix 2.0.
    WHP~231 WTQ~207 VDR Dyno http://i70.photobucket.com/albums/i1...ps03a88b79.jpg
    I lack color... verified
    Aug 1998
    Awesome!!! Great work!
    Since then I came up with an even easier way to tune. Set the fuel table to your desired AFR and use the MAF smoothing table to do the percentage correction.
    this is good, be slightly careful though. Depending on where and how exactly you start a pull the afrs can move just a bit. Me personally I wouldn't go more than 50-70% of the way there in each adjustment, but apparently my caution didn't help me, LOL.
    That's pretty cool... !! kind of like a safc.. but then Karmen HZ would be equivalent to Load?
    I got a question.. for my AFR values.. I have a NA.
    I am trying to make a guide of what AFR values represent on the fuel map.. this is stock afr map.
    could you correct me on this picture if you see anything wrong?
