Results 1 to 8 of 8
Thread: the PCV conundrum
    wheatfield, IN
    the PCV conundrum
    I've been thinking after the sudden loss of one of my "prized 13T turbos" I've been going over all of my systems to find what caused the failure before I drop in the new 20T's. after looking at the PCV system as a whole, I keep running into the same wall. I'll explain my understanding of the stock system first to maybe find a major flaw in my train of thought before we get into the question at hand.
    The Stock system as I understand it:
    at 0 psi and below, vaccuum is drawn by the lower intake plenum on the front valve covers pcv.
    under positive intake pressure, the front valve covers PCV check ball closes blocking that port from pressurizing the crank case. vaccuum is then drawn by the pre turbo intake pipe onto the rear valve cover.
    the Flaw I see in this system: at 0 PSI and below, fresh air can be brought in through the intakes connection to the rear valve cover, but when the system is under boost, the preturbo connection applies vaccuum to the crankcase. but the front valve cover's PCV is being forced closed by the pressurized intake plenum, assuming you have a leak free system, WHERE DOES THE FRESH AIR COME FROM NOW? is the crankcase supposed to be under vacuum? or open to allow fresh air to flow through the system and move with the blowby gases?
    under boost it lets crank case pressure out the rear. The engine isn't under vacuum under boost. Not sure what you're getting at because I'm tired. Will post again tomorrow.
    wheatfield, IN
    the engine isn't under vacuum POST turbo, before the turbo however, air is being sucked in
    I think you are confused by the term "ventilation" in PCV. Slight vacuum is the end goal.
    wheatfield, IN
    post Throttlebody vacuum "where the front valve cover is connected" will be higher than pre turbo vacuum "where the rear valve cover is connected, so the crankcase won't see "vacuum" so much as flow or "ventilation" across the heads, but when one side of the system is blocked "front pcv under boost" the rear valve cover port will still suck air, which would create vacuum, not ventilation because the only way for more air to enter the system is blowby itself. which I can't fathom being enough volume to satisfy the draw of two turbos "i realize this isn't the only source of air for the turbos to intake, but i would think a large enough vacuum would be place on the system.
    The stock PCV system works, plain & simple.
    The pcv system is there to vent the positive pressure created by piston ring blow by. It will vent pressure with no vacuum source attached to it. Look at it this way. Positive crank pressure is vented to the lower intake under vacuum, and the pre turbo intake pipes under boost.
    If you've got vacuum in the rear cam cover breather under boost with the stock setup you have a Seriously blocked air filer..
    No thing wrong with the pcv if the check valve is working on the front valve cover and you haven't got horrendous blow-by from the piston rings..
