1995 Dodge Stealth R/T Turbo
pics added
Just thought I would add that the rear diff came out a Z15 chassis car, so it has no hole for the rear power steering pump. Perfect if you have done AWS delete![]()
Make an offer.
Dumb question will the 6spd rear diff work with a 5spd gto awd?
I don't believe so. I'm pretty sure all JDMs use the equivalent of the 5 speed USDM rear diff. Regardless all these parts are now sold.
All 5 speeds have the same ratios, and use the same rear diff. It's the Japanese 6-speed that needs a US 5-speed rear diff in order to work correctly.Dumb question will the 6spd rear diff work with a 5spd gto awd?
