We are saying the same thing and you're beating your head against a wall trying to explain the same thing I already said. I could reduce the timing and the boost and then again prove the same thing. Adding the C16 to the mix, you would think would get the octane value near what the methanol brings when injected. The C16 mix with 93 only proves that the cooling effect that methanol adds allows the settings to be turned up to the levels they are without knocking. It's genious and right up your ally, bang for the buck. Maybe saying it differently will get you to see that. It's the same as running straight C16 vs the pump/meth mix with all the settings staying the same. Will it make more power just doing that? No. It has to be tuned/optimized. Can it make more? It should.
The reason I have chosen to run as much methanol as possible was your idea when you were running the 720's trying to stretch the capability of the arc. I'm stretching the capability of simply running 93 and filling my little tank occasionally with methanol.
Jeff
