Results 1 to 8 of 8
Thread: Clutch issue , input needed
    SoSoCal verified
    I was getting ready for the TX gathering and Alan (bboyalan) was tuning my car. On day one we coudnt get past 17psi. Turns out I forgot to put the stiff spring into the MBC. I change it out and it easily goes 20psi but I am taking it easy as it is not completely tuned yet. On day two of tuning, one run at 20psi in 2nd gear and at the end of the pull I shift to 3rd gear and something dont feel right clutching. Felt spongy and got some noises realeasing clutch. Pull over and try to get away in first, lots of noise/grinding kinda sound spongy but shifting overall is fine. We are thinking master cylinder, specifically because there is a big droplet below the dash. So I drove it home as good as possible. Next day I bring it to my shop of choice and I asked them to change out the master and slave cylinders as reagrdless of the problem they got 137k on it.
    Today I get it back with new cylinders and as I am going for a test drive same problem. I back into my parking spot and talk to the owner and tech. He suggest we take it for a ride together and get a feeling of the sounds/feel of clutch. Half way into the ride the sounds go away , no more spongyness feels like normal. I ask the owner/tech could it be that the hydraulic system needed some time to adjust. He says no. I drive the car home in stop and go traffic and all is fine.
    Is this normal, I appreciate the input. Sorry for the long story lol.
    Mark
    Ann Arbor, MI
    Sponginess would likely be air in the system, I would give the line a good bleeding and look for air bubbles.
    Beyond that, man, I don't know what to say about the noises. Sounds like the clutch wasn't disengaging due to the sponginess and you were hearing grinding gears.
    Alex
    SoSoCal verified
    Not the gears, this was more of the flywheel clutch grinding
    Ann Arbor, MI
    Weird, usually when the throw out bearing is seized or going out you hear a squeal, but not a grinding.
    I'll let someone else speak up, this one has me stumped.
    SoSoCal verified
    We are wondering too if possibly a spring or rivet came out of the clutch as we did revved it to 7000rpms at 20psi , maybe the spring popped back in or the rivet found its way somewhere.
    August 2010
    Chicago
    What kind of clutch? had a vr4 at the shop last week..got locked out of gear..ended up being a spring popped out. if hydraulics are new there isnt much left except trans cables or the clutch.
    SoSoCal verified
    DXD FE. All gears are shifting perfectly
    SoSoCal verified
    I am letting it cool down completely and see if in the morning there are the same symptoms.
