I found some slightly different numbers, The TEIN and JIC numbers came off of there webpages a year ago and the stock rates I copied off a post on Team3S so I am pretty sure they are good but I haven't personally verified it.
Spring Rates of Suspenions:
After Market Spring Rates:
JIC FLTA2 Series, Turbo AWD Front: 787 lbs/in Rear: 564 lbs/in, 14/10 KG/MM
JIC FLTA2 Series, NA FWD Front: 787 lbs/in Rear: 506 lbs/in, 14/9 KG/MM
TEIN HA Series, Turbo AWD Front: 671 lbs/in Rear: 448 lbs/in, 12/8 KG/MM
Eibach (2811.140) Pro-kit Series variable rate, Front: 228 to 428lbs, Rear: 154 to 228 lbs.
Intrax ?
Optional Spring rates, almost all manufaturers have optional rates these are just the ones I know of:
TEIN HA Series, Turbo AWD 564 lbs/in front 336 lbs/in ReaR, 10/6 KG/MM
A Tein dealer told me that 10/6kg/MM was as soft as you could go w/o re-valving the springs,
He also quoted me $230 for springs purchased separately or no cost to get them as part of a coil-over set
Stock Spring Rates:
Thanks to Eric Gross who Posted stock Spring rates and strut dampening rates on Team 3S
All units in N/mm (lbs/in.)
Stock Spring Constants
'92-'93 FWD AWD
Front 30 (168) 39 (218)
Rear 35 (196) 28 (157)
'94+ Front 29 (162) 38 (212)
Rear 34 (190) 28 (157)
Spyder
Shock Damping Forces (0.3m/s or 0.984ft/sec)
ECS (all) Expansion Contraction
Front Hard 2530(558) 1190(262)
Front Med 1580(348) 1120(247)
Front Soft 620(214) 970(214)
Rear Hard 1710(377) 1010(223)
Rear Med 1160(256) 880(194)
Rear Soft 560(123) 670(146)
Non-ECS Expansion Contraction
Front 1080(238) 540(119)
Rear 1000(220) 550(121)
