Under sensor scaling and pin 92 enter these values
Volts:
0.6274509803921569
1.137254901960784
1.607843137254902
3.882352941176471
4.921568627450981
PSI:
-14.7845
-9.02
-4.353499999999999
0.03850000000000264
20.07700000000001
29.41
In Evoscan I have this formula for MAP scaled
x*0.2745-19.1
Check the box in Evoscan then validate the readings with a pressure pump. If all the readings are off by say +1psi then consider changing the value in Evoscan. If the readings are all over the place both + and - then change the values in Ecuflash to match. As long as the actual pressure is the same as displayed pressure then you're good reguardless of how flaky the inputs look to both the logger and the tune.
Jeff
